주요 콘텐츠로 건너뛰기
Samsung Galaxy Nexus SIM Card Replacement
필요한 것
  1. Samsung Galaxy Nexus SIM Card Replacement, Back of Phone: 1 단계, 이미지 1/1
    • You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
  2. Samsung Galaxy Nexus SIM Card Replacement, Removal of Back Cover: 2 단계, 이미지 1/3 Samsung Galaxy Nexus SIM Card Replacement, Removal of Back Cover: 2 단계, 이미지 2/3 Samsung Galaxy Nexus SIM Card Replacement, Removal of Back Cover: 2 단계, 이미지 3/3
    • Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
  3. Samsung Galaxy Nexus SIM Card Replacement, Removal of Battery: 3 단계, 이미지 1/3 Samsung Galaxy Nexus SIM Card Replacement, Removal of Battery: 3 단계, 이미지 2/3 Samsung Galaxy Nexus SIM Card Replacement, Removal of Battery: 3 단계, 이미지 3/3
    • Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
    • This is when a new battery will be inserted.
  4. Samsung Galaxy Nexus SIM Card Replacement, Back Cover of Phone: 4 단계, 이미지 1/3 Samsung Galaxy Nexus SIM Card Replacement, Back Cover of Phone: 4 단계, 이미지 2/3 Samsung Galaxy Nexus SIM Card Replacement, Back Cover of Phone: 4 단계, 이미지 3/3
    • Using your fingers pull the Sim card out.
    • This is a Verizon phone, however we are using a AT&T Sim card as an example as to where to put the sim card.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Stephan Williams
회원 가입일: 09/22/14
1,482 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,940
