주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 10.1 2014 Battery Replacement
필요한 것
  1. Samsung Galaxy Note 10.1 2014 Battery Replacement, Case: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Note 10.1 2014 Battery Replacement, Case: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $2.99
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  2. Samsung Galaxy Note 10.1 2014 Battery Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
    • Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
  3. Samsung Galaxy Note 10.1 2014 Battery Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Phillips #000 Screwdriver
    $5.49
  4. Samsung Galaxy Note 10.1 2014 Battery Replacement: 4 단계, 이미지 2개 중 1개 Samsung Galaxy Note 10.1 2014 Battery Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $2.99
    • Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
    • Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
결론
다른 27명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joseph Rasico
회원 가입일: 02/20/17
2,200 평판
안내서 6개를 작성함
USF Tampa, Team S1-G6, Leahy Spring 2017 USF Tampa, Team S1-G6, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G6
3 회원들
안내서 6개를 작성함
댓글 5개
Step 1 you have to show the back cover to remove. Showing the front side is confusing.
After step 4 there should be a step 5 to show how to disconnect the white connector with the colored wires: it took time to discover that you have to lift the 2 side clips, and not to pull…
prisca - 답글
Just followed your instructions. Used a online kit with a guitar pick-like spudger. Had to wrestle with it slightly, but everything worked out perfectly to your instructions.
Matt - 답글
You said it was like a guitar pick so I used a guitar pick. Worked pretty well. Guitar pick is bent up but they are cheap.
Stephen Nichols -
Followed the instructions. Worked nearly perfectly. The last step is a bit tricky. Just look at the new battery to understand the system.
Eramur - 답글
Something I won’t be doing again. It was very annoying to do and nerve racking to complete. Was a pain to snap back together.
Bradley Carr - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 71
전체 시간: 22,573
