주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 10.1 2014 Rear Camera Replacement
필요한 것
  1. Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, Case: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, Case: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $2.99
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  2. Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, Loudspeaker Modules: 2 단계, 이미지 2개 중 1개 Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, Loudspeaker Modules: 2 단계, 이미지 2개 중 2개
    • Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
    • Remove the one 3mm screw on the top left side of the device with the same method.
  3. Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, loudspeaker  - remove right speaker: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, loudspeaker  - remove right speaker: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, loudspeaker  - remove right speaker: 3 단계, 이미지 3개 중 3개
    • Remove the gray rubber piece.
    • Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
    • Remove the right speaker unit.
  4. Samsung Galaxy Note 10.1 2014 Rear Camera Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Note 10.1 2014 Rear Camera Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Note 10.1 2014 Rear Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the loudspeaker modules located on the parts where the screws were removed by using the black nylon spudger.
    • They are the black pieces at the top left and right corners of the device that have metal squares on them in the middle.
  5. Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
    • Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
  6. Samsung Galaxy Note 10.1 2014 Rear Camera Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Phillips #000 Screwdriver
    $5.49
  7. Samsung Galaxy Note 10.1 2014 Rear Camera Replacement: 7 단계, 이미지 2개 중 1개 Samsung Galaxy Note 10.1 2014 Rear Camera Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $2.99
    • Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
    • Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
  8. Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, Motherboard: 8 단계, 이미지 3개 중 1개 Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, Motherboard: 8 단계, 이미지 3개 중 2개 Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, Motherboard: 8 단계, 이미지 3개 중 3개
    • Disconnect all cables on the motherboard.
    • See our connector guide for help safely disconnecting various types of connectors.
  9. Samsung Galaxy Note 10.1 2014 Rear Camera Replacement: 9 단계, 이미지 3개 중 1개 Samsung Galaxy Note 10.1 2014 Rear Camera Replacement: 9 단계, 이미지 3개 중 2개 Samsung Galaxy Note 10.1 2014 Rear Camera Replacement: 9 단계, 이미지 3개 중 3개
    • Use the black nylon spudger to gently lift the motherboard away from the frame.
    • Remove the motherboard.
  10. Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, Rear Camera: 10 단계, 이미지 2개 중 1개 Samsung Galaxy Note 10.1 2014 Rear Camera Replacement, Rear Camera: 10 단계, 이미지 2개 중 2개
    • Disconnect the camera piece from the motherboard.
    • The camera piece is shaped like an "L".
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Joseph Rasico
회원 가입일: 02/20/17
2,200 평판
안내서 6개를 작성함
USF Tampa, Team S1-G6, Leahy Spring 2017 USF Tampa, Team S1-G6, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G6
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 871
