주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement
필요한 것
  1. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: 1 단계, 이미지 1/3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: 1 단계, 이미지 2/3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: 1 단계, 이미지 3/3
    • This is the back of the device and where you will begin to take it apart.
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use a metal spudger to pop up the corner of the silver piece.
    • Use the plastic opening tools to pry along the edges of the silver piece.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 2 단계, 이미지 3/3
    • Remove the three 5mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 3 단계, 이미지 3/3
    • Remove the three 2 mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Starting with the black motherboard connector, remove the module indicated by the orange box in the second picture.
    • Replace the 3.5 mm auxiliary port with a similar model.
결론
Gavin Tipker
회원 가입일: 11/01/18
193 평판
안내서 2개 작성하였습니다
IUPUI, Team S3-G1, Harley Fall 2018 IUPUI, Team S3-G1, Harley Fall 2018 회원
IUPUI-HARLEY-F18S3G1
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,025
