주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 10.1 Battery Replacement
필요한 것
  1. Samsung Galaxy Note 10.1 Battery Replacement, Removing the Top Piece: 1 단계, 이미지 1/3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Top Piece: 1 단계, 이미지 2/3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Top Piece: 1 단계, 이미지 3/3
    • This is the back of the device and where you will begin to take it apart
    • It is neccesary to remove this piece first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Battery Replacement, Removing the Back Cover: 2 단계, 이미지 1/3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Back Cover: 2 단계, 이미지 2/3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Back Cover: 2 단계, 이미지 3/3
    • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Battery Replacement, Removing components covering battery: 3 단계, 이미지 1/3 Samsung Galaxy Note 10.1 Battery Replacement, Removing components covering battery: 3 단계, 이미지 2/3 Samsung Galaxy Note 10.1 Battery Replacement, Removing components covering battery: 3 단계, 이미지 3/3
    • Carefully remove all of the ribbons that connect over the battery.
  4. Samsung Galaxy Note 10.1 Battery Replacement, Removing the Battery: 4 단계, 이미지 1/3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Battery: 4 단계, 이미지 2/3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Battery: 4 단계, 이미지 3/3
    • Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
결론
다른 49명이 해당 안내서를 완성하였습니다.
Tyler Salomone
회원 가입일: 09/22/14
1,020 평판
안내서 3개 작성하였습니다
USF Tampa, Team 3-7, Brown Fall 2014 USF Tampa, Team 3-7, Brown Fall 2014 회원
USFT-BROWN-F14S3G7
3 회원들
안내서 9개 작성하였습니다
댓글 13개
In Step 3, mention that you need to lift up on the black locks to take out the ribbons.
John Peterson - 답글
Actually, on my device one lock was colored faun (beige). Lift them seen from the edge of the Note, not on the cable side.
dada64 -
Also, mention that you can disconnect the battery from the device by gently pulling out the battery and gently lifting up the wires.
John Peterson - 답글
This is not a plug to be pulled in the direction of the cables but vertically off the board. Putting it back in you simply plug the contacts down first, then the cable side of the plug.
dada64 -
When replacing the back cover, hook the bottom edge into the frame along the edge before trying to snap the rest in place along the sides.
charliesmallman55 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 18
30일 전: 111
전체 시간: 88,750
