주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 10.1 Rear Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: 1 단계, 이미지 1/3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: 1 단계, 이미지 2/3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: 1 단계, 이미지 3/3
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: 2 단계, 이미지 1/3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: 2 단계, 이미지 2/3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: 2 단계, 이미지 3/3
    • Unscrew the three screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: 3 단계, 이미지 1/3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: 3 단계, 이미지 2/3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: 3 단계, 이미지 3/3
    • Start by lifting the white connector to remove the part indicated by the red polygon.
    • Gently pry along the camera hub to lift it out of its location.
    • This is your camera. Replace it with the new part.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Bryan Fernandez
회원 가입일: 09/22/14
241 평판
안내서 2개 작성하였습니다
USF Tampa, Team 3-7, Brown Fall 2014 USF Tampa, Team 3-7, Brown Fall 2014 회원
USFT-BROWN-F14S3G7
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 15
전체 시간: 2,200
