소개
Follow the steps in order to replace your battery.
If your battery is swollen, take appropriate precautions.
도구
지정된 도구가 없습니다.
부품
Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
Slide your fingernail or plastic opening tool along the edge of the rear case.
Lift the case gently from the base.
Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
Lift the battery out of its recess.
다른 41명이 해당 안내서를 완성하였습니다.
