소개
This guide shows how to replace the camera.
필요한 것
Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
Slide your fingernail or plastic opening tool along the edge of the rear case.
Lift the case gently from the base.
Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
Lift the battery out of its recess.
Place your fingernail in the groove of the stylus pen.
Pull the stylus pen away from the phone.
Insert the plastic opening tool into the Stylus Pen placement holder.
Lift the plastic opening tool so that the midframe separates from the base.
Remove the single screw beside headphone jack.
You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
Use tweezers to remove both antenna clips.
Use a spudger to disconnect six cable connectors.
Pull up on the motherboard with tweezers.
My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
soha Javed - 답글
My wifi hotspot is not working
Unclip the camera connecting cable using the plastic opening tool from the motherboard
Remove loose camera from base
다른 37명이 해당 안내서를 완성하였습니다.
댓글 3개
Hi
Thanks for the nice instructions
Do you know if I can use a Note 4 camera (or any better!) for my Note 3?
Are they different in connections?
Thanks
I shall be very thankfull for this act of kindness
