주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 3 Rear Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove the rear case: 1 단계, 이미지 1/1
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: 2 단계, 이미지 1/2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: 2 단계, 이미지 2/2
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Why... is it not simple enough already lol
    Adam Ahmed - 답글
  3. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: 3 단계, 이미지 1/2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: 3 단계, 이미지 2/2
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Rear Facing Camera Replacement, S Pen: 4 단계, 이미지 1/1
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unscrew Back Chassis: 5 단계, 이미지 1/1
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Back Chassis: 6 단계, 이미지 1/1
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: 7 단계, 이미지 1/2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: 7 단계, 이미지 2/2
    • Remove the single screw beside headphone jack.
    You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
    Oriol Felisart - 답글
  8. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: 8 단계, 이미지 1/2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: 8 단계, 이미지 2/2
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Motherboard Removal: 9 단계, 이미지 1/1
    • Pull up on the motherboard with tweezers.
    Can i change at&t board to 9002 or 9005??,
    Ayyaz - 답글
    My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
    soha Javed - 답글
    My wifi hotspot is not working
    Kiran Thopate - 답글
  10. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unclipping the Camera: 10 단계, 이미지 1/1
    • Unclip the camera connecting cable using the plastic opening tool from the motherboard
    • Remove loose camera from base
결론
다른 37명이 해당 안내서를 완성하였습니다.
Brittany Gail
회원 가입일: 09/23/14
8,504 평판
안내서 8개 작성하였습니다
USF Tampa, Team 2-2, Blackwell Fall 2014 USF Tampa, Team 2-2, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S2G2
4 회원들
안내서 25개 작성하였습니다
댓글 3개
Awesome, phone disassembly and fingernail painting at same time :) Thanks for your time to post this!
Chris G - 답글
Hi
Thanks for the nice instructions
Do you know if I can use a Note 4 camera (or any better!) for my Note 3?
Are they different in connections?
Thanks
hameidfehri - 답글
I shall be very thankfull for this act of kindness
Malik wajdan ali - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 13,430
