주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note 4 Front Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Note 4 Front Facing Camera Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Note 4 Front Facing Camera Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy Note 4 Front Facing Camera Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
  3. Samsung Galaxy Note 4 Front Facing Camera Replacement, SIM Card: 3 단계, 이미지 2개 중 1개 Samsung Galaxy Note 4 Front Facing Camera Replacement, SIM Card: 3 단계, 이미지 2개 중 2개
    • Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
  4. Samsung Galaxy Note 4 Front Facing Camera Replacement, Midframe: 4 단계, 이미지 1개 중 1개
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  5. Samsung Galaxy Note 4 Front Facing Camera Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Note 4 Front Facing Camera Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Note 4 Front Facing Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  6. Samsung Galaxy Note 4 Front Facing Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  7. Samsung Galaxy Note 4 Front Facing Camera Replacement: 7 단계, 이미지 3개 중 1개 Samsung Galaxy Note 4 Front Facing Camera Replacement: 7 단계, 이미지 3개 중 2개 Samsung Galaxy Note 4 Front Facing Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  8. Samsung Galaxy Note 4 Front Facing Camera Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove the two 2.9 mm Phillips #00 screws.
  9. Samsung Galaxy Note 4 Front Facing Camera Replacement: 9 단계, 이미지 2개 중 1개 Samsung Galaxy Note 4 Front Facing Camera Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a set of tweezers to remove the two antenna cables.
  10. Samsung Galaxy Note 4 Front Facing Camera Replacement: 10 단계, 이미지 3개 중 1개 Samsung Galaxy Note 4 Front Facing Camera Replacement: 10 단계, 이미지 3개 중 2개 Samsung Galaxy Note 4 Front Facing Camera Replacement: 10 단계, 이미지 3개 중 3개
    • Use a set of tweezers or the flat end of a spudger to disconnect the two ribbon cable connectors.
  11. Samsung Galaxy Note 4 Front Facing Camera Replacement: 11 단계, 이미지 1개 중 1개
    • Gently lift the motherboard out of the phone.
  12. Samsung Galaxy Note 4 Front Facing Camera Replacement, Front Facing Camera: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Turn the motherboard over.
    • Lift the metal tab up with the tweezers.
  13. Samsung Galaxy Note 4 Front Facing Camera Replacement, Unclip Plastic Clips: 13 단계, 이미지 2개 중 1개 Samsung Galaxy Note 4 Front Facing Camera Replacement, Unclip Plastic Clips: 13 단계, 이미지 2개 중 2개
    • Turn the motherboard back over.
    • Unclip the two plastic clips that connect the rear camera to the motherboard with your fingers.
결론
다른 15명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Derek Nola
회원 가입일: 01/06/15
2,280 평판
안내서 5개를 작성함
Cal Poly, Team 70-6, Forte Winter 2015 Cal Poly, Team 70-6, Forte Winter 2015 회원
CPSU-FORTE-W15S70G6
4 회원들
안내서 16개를 작성함
3가이드 댓글
I change my LCD screen and camera stopped working. I bought new one and still no result. Please help !
ivaylo.lord - 답글 공유
Have the same problem with the front camera. changed LCD und suddenly the front camera stopped working. bought 2 new ones and both the same. The IR-blaster sill works
Tuerkay - 답글 공유
stopped front camera
Negatu Getahun - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 84
전체 시간: 13,992
