주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 4 Motherboard Replacement
필요한 것
  1. Samsung Galaxy Note 4 Motherboard Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Note 4 Motherboard Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy Note 4 Motherboard Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
  3. Samsung Galaxy Note 4 Motherboard Replacement, SIM Card: 3 단계, 이미지 2개 중 1개 Samsung Galaxy Note 4 Motherboard Replacement, SIM Card: 3 단계, 이미지 2개 중 2개
    • Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
  4. Samsung Galaxy Note 4 Motherboard Replacement, Midframe: 4 단계, 이미지 1개 중 1개
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  5. Samsung Galaxy Note 4 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Note 4 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Note 4 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  6. Samsung Galaxy Note 4 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  7. Samsung Galaxy Note 4 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Samsung Galaxy Note 4 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Samsung Galaxy Note 4 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  8. Samsung Galaxy Note 4 Motherboard Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove the two 2.9 mm Phillips #00 screws.
  9. Samsung Galaxy Note 4 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Samsung Galaxy Note 4 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a set of tweezers to remove the two antenna cables.
  10. Samsung Galaxy Note 4 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Samsung Galaxy Note 4 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Samsung Galaxy Note 4 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Use a set of tweezers or the flat end of a spudger to disconnect the two ribbon cable connectors.
  11. Samsung Galaxy Note 4 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Gently lift the motherboard out of the phone.
결론
다른 112명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Geoff Wacker
회원 가입일: 09/30/13
91,987 평판
안내서 89개를 작성함
67가이드 댓글
Are all variants of the note 4 the same? An att mobo could go into a vzw/sprint body or vice versa?
Jeb - 답글
I would also really like an answer to this question
pcwireless -
No. Even Samsung wouldn't accept even a paid repair because parts between models are incompatible.
I've tried to have an SM-910G here and if you are to replace it with an SM-910C, you'll also need to replace the front and back cameras.
Ian Troy Alvaran -
I have done a few Note 4 motherboard replacements...about 10 or so. I have not been able to simply "To reassemble your device, follow these instructions in reverse order." I always have to separate the screen from the mid frame in order to plug the 2 top ribbon cables back to the motherboard. I can't figure out a way to get the ribbon cables plugged back in without doing so. This screen separation process is very tedious, long, and stressful as it could crack the AMOLED screen if you're not careful. If someone can show me exactly how to simply, "To reassemble your device, follow these instructions in reverse order" it'll make it a lot easier for me. Thanks.
KengkoyFlip - 답글
Agreed. That screen was by far the most difficult screen ive ever removed from a phone. It would be SOOO much easier if it were broken and you didn't care.
trentmrobertson -
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 98
지난 30일: 466
전체 시간: 149,197
