주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 4 SIM Card Replacement
필요한 것
  1. Samsung Galaxy Note 4 SIM Card Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy Note 4 SIM Card Replacement, Rear Case: 1 단계, 이미지 2/2
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
    Back is not flexible and will shatter
    bobby moran - 답글
  2. Samsung Galaxy Note 4 SIM Card Replacement, Battery: 2 단계, 이미지 1/1
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
  3. Samsung Galaxy Note 4 SIM Card Replacement, SIM Card: 3 단계, 이미지 1/2 Samsung Galaxy Note 4 SIM Card Replacement, SIM Card: 3 단계, 이미지 2/2
    • Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
결론
다른 31명이 해당 안내서를 완성하였습니다.
Derek Nola
회원 가입일: 01/06/15
2,244 평판
안내서 5개 작성하였습니다
Cal Poly, Team 70-6, Forte Winter 2015 Cal Poly, Team 70-6, Forte Winter 2015 회원
CPSU-FORTE-W15S70G6
4 회원들
안내서 16개 작성하였습니다
댓글 3개
Many thanks my bro
goooooogle319 - 답글
Theres 5 pins next to sim card port. Can i ask..what is the purpose of that pin?
Nirza Dhom - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 56
전체 시간: 11,186
