주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 5 Back Cover Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy Note 5 Back Cover Replacement, Samsung Galaxy Note 5 Back Cover Replacement: 1 단계, 이미지 1/1
    • Heat the back cover to melt the strong adhesive sticker underneath.
  2. Samsung Galaxy Note 5 Back Cover Replacement: 2 단계, 이미지 1/1
    • Try to pull and open a gap between back cover and frame after heat. Insert into a guitar pick to cut the sticker.
    Is it possible to pull it without breaking it?? :/
    Mohammad - 답글
  3. Samsung Galaxy Note 5 Back Cover Replacement: 3 단계, 이미지 1/1
    • If you do it hardly, you need much more heat especially the edged side.
    • Slipping a playing card through the gap is a good way to loosen up the adhesive.
  4. Samsung Galaxy Note 5 Back Cover Replacement: 4 단계, 이미지 1/1
    • Remove the back cover. The white stripe is the sticker.
결론
다른 45명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 9개
What about putting the one back on?
rcf917 - 답글
will it go back on and stay on without new adhesive?
dfasdfjiun - 답글
I suggest that you take new adhesive, old adhesive is not strong enough to hold back cover.
Witrigs -
You can check this video of put it back battery cover : https://www.youtube.com/watch?v=3HrmeVGY...
Witrigs - 답글
How do I remove the sticky part
Marcelino Lopez - 답글
How to put the cover back will there be a sticker in battery cover. And from where I will get to buy that
BIJLI R - 답글
Where do you find the replacement back for sale? I looked on the Samsung site, and no luck.
Marty Meyer - 답글
Hey I know its old but amazon has some back covers
Francisco Vazquez -
Anyone have a problem with one that is bricked won't charge and won't turn on but yet a wireless charger appear to be giving it a charge as light goes solid on charger when it is in contact what should I do this phone looks in great shape almost new condition
Johnathon Patterson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 26
전체 시간: 108,750
