이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Try to pull and open a gap between back cover and frame after heat. Insert into a guitar pick to cut the sticker.
If you do it hardly, you need much more heat especially the edged side.
Slipping a playing card through the gap is a good way to loosen up the adhesive.
다른 45명이 해당 안내서를 완성하였습니다.
댓글 9개
will it go back on and stay on without new adhesive?
dfasdfjiun - 답글
I suggest that you take new adhesive, old adhesive is not strong enough to hold back cover.
Witrigs -
You can check this video of put it back battery cover : https://www.youtube.com/watch?v=3HrmeVGY...
How do I remove the sticky part
