소개
Use this guide to replace a cracked or broken display on your Samsung Galaxy Note8.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the display while leaving the original frame, logic board, and battery in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure—transplanting your phone's internals and installing a new battery. Make sure you have the correct part before starting this guide.
This guide involves removing the rear glass cover, you will need replacement adhesive to reattach the back cover to the phone. If your replacement display does not come with adhesive, you will need to use tape to secure it. Opening the Samsung Galaxy Note8 will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will loose its water-protection.
If the frame is damaged or bent, it's important to replace it, or else the new screen may not mount correctly and can suffer damage from uneven pressure.
The process of separating the display from the frame usually destroys the display, so don't follow this guide unless you intend to replace the display.
필요한 것
Switch off your phone.
Prepare an iOpener for softening the adhesive on the back of the Note8.
Apply the iOpener on the back of the Note8 along the side with the power button.
Use a suction handle to lift the back cover and create an opening pick to get in the gap.
Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
Use another pick and move it to the top corner.
I used an X-acto knife with the flat blade to get it started. I tried using the suction cup - but it’s difficult to get good leverage. Once I got the cover started - I used the metal pry tool (sharpened with a dremel file) and a business card to work it open.
This is definitely the hardest part.
Once off I see all the glue on the curved part of the chassis NOTON THE BACK. Apply heat to curved edges.
Lyle Walsh - 답글
When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
I broke the back camera cover for the NUT 8 and then I bought a commercial cover and installed it but the quality of the picture became very bad and my question is, do you know where to get the original cover at a reasonable price?
Use a pair of tweezers to disconnect the fingerprint sensor.
don't skip disconnecting the sensor, even if isn't still glued to the case. it has to move away from the NFC/charging coil assembly in order to free the latter so it can be lifted away from the battery.
Remove the back cover.
How do you swap the fingerprint sensor
Lukus Carr - 답글
You can use a tweezer to swap the fingerprint sensor, you might be careful when doing the step 6, additionally, a tweezer will be helpful when reassemble the fingerprint sensor. please note that your new back cover needs to have the fingerprint adhesive on. most of the product did not have. i have get a LUVSS brand from amazon which came with all OEM adhesive and full set tools, even a B6000 glue, best option to go for replacing the note 8 back glass
Use an opening pick at the top edge to get between the NFC antenna and charging coil assembly and the case.
Lever the top of the assembly out of the case.
Remove the six Phillips #00 screws on the loudspeaker assembly at the bottom of the phone.
Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
Lay overlapping strips of clear packing tape over the Note8's display until the whole face is covered.
This will keep glass shards contained and provide structural integrity when prying and lifting the display.
Once the screen is warm to the touch, apply a suction cup to the lower edge of the phone.
If the phone's screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
Lift on the suction cup, and insert a halberd spudger or an opening pick under the display assembly.
Start to slide the halberd spudger/opening pick along the lower edge of the phone to cut the adhesive. Leave an opening pick at the corner to prevent the adhesive from resealing.
Continue to slide the halberd spudger/opening pick along the side of the phone and insert another opening pick.
Slide the halberd spudger/opening pick to the upper corner of the phone to cut the adhesive and insert and opening pick to prevent the adhesive from sticking to the display.
Repeat the previous heating and cutting procedure for the remaining sides of the phone. Insert an opening pick on every corner and on both sides of the Note8.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
After reapplying adhesive, follow these instructions in reverse order to reassemble your device.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
다른 99명이 해당 안내서를 완성하였습니다.
댓글 21개
I’m sorry, but this is just a preview question. When the guide says display, does it mean only the glass screen or the LCD and digetizer as well?
Hello Adrian Gomez. Here “display” refers to the glass, digitizer and LCD combo—those are fused together.
For this repair, do I need to buy the 230 dollar screen part as well?
This guide here is for replacing only the screen without the frame (which we currently don’t have in store). The 230 dollar part includes the frame and the according guide can be found here: Samsung Galaxy Note8 Display Assembly with Frame Replacement
Hi
I replace the new disply the camera ( front is working ) is not working I tried many things such as factory settings put it didn’t work
now I orderd a new camera hope it works or there is another way to solve it
nasser
zarmat2002 - 답글
I replaced my first cracked display screen today. Everything went quit smoothly thanks to Dominik . Thanks for the guide.
Can I purchase just a replacement front screen and digitiser (easily available on fleabay) to replace a cracked front Note8 screen?
Turns out that the screen+ digitiser are widely available without the LCF fused into them.
Thank you.
Hi ILM, separating the actual display from the front glass/digitizer is a cumbersome procedure that requires special tools. Same goes for fusing them together again. This could be done in well-equipped repair shops. Going for a combined display+digitizer assembly replacement is mostly the way to go for a “regular user” repair.
On part 19 the gold foil what is that and why have non of the parts ive bough come w it
Hi there,
Thank you for the guide and What is your opinion and recommendation on non-original (but fairly looking good)displays that we can buy online? Should we adhere to replace with original parts? What are the most possible consequences that can occur in such non-original replacements? Please share your ideas.
Hi uchira subhashana,
aftermarket screens can work well for repairs and often they are unbranded original parts. So there is nothing wrong with that. However you can’t say this in general because at the end of the day it always depends on where you buy the screen. Not all retailers are evenly reliable and you should always try to find a safe source like iFixit is. Worst that can happen with an aftermarket screen is that the new screen is not working but usually this wont harm your phone and you can send it back. This can happen with original frames as well.
will be awesome if you leave a links with all things we have to buy to do this.
Is there a safe reliable source for just the lcd/screen without the frame? A $200+ repair with 2+ hours of labor makes a hard sell.
I'm none to sanguine on the available options on amazon.
Thankyou again for the amazing guide.
Anyone have any recommendations?
Sorry for the delay, its awesome that you want to get into phone repair as it helps the environment and saves money!
https://www.megafixit.com/products/samsu...
I am repairing a note 8 myself, and will use this display totalling ~$180
Hop efully you guys can help me out, I did this procedure but when turning on the phone with the new display speaker, audio jack not working and Sim not recognized and everything was working properly before with the old screen.
Does iFixit sell display adhesive? if not where can i find some
You can use this double sided adhesive or pre-cut adhesive like this one (select different widths and pre-cut with the dropdown menu).
Is it good to use a glue or a double sided tesa tape to assemble everything back?
You might want to follow the link from two comment above for suitable adhesive :)
I used a heat gun to soften the glue - worked it around the edges, moving the heat gun quickly. As this is my first attempt, I’m still calibrating on this - but other guides mention getting the back cover hot enough so as it’s just too hot to touch. I also have a temp probe on my multi-meter, and I measured appx. 75 deg. C.
One of the other guides showed using a electronics hot plate set to 105 deg C for 60 sec.
Phil Brooks - 답글
