소개
The back cover is the cover to all of the inner components of the tablet. If you need to access any of those parts, you must start by removing the back cover. Alternatively, your back cover may receive wear and tear over time from use, which could result in it cracking and needing to be replaced. In either case, this guide will show you how to remove or replace the back case.
필요한 것
Work your way around the entire device by carefully prying and sliding the plastic opening tool.
다른 16명이 해당 안내서를 완성하였습니다.
댓글 5개
news flash that phone in the picture is NOT a note 8
Nic Wilson - 답글
As stated in the title, this is regarding Galaxy Note 8.0 ( 2013 ), not for Note 8 Phone.
deadyoda -
Thanks for the guide, helped me to add a QI module into my Galaxy Note 8.0
deadyoda -
Thanks for sharing this useful guide! Also, if issue is related with software, we can use unbrick guide to get it repair.
Cheers!
Thanks for sharing this info for the basic understanding. I always wanted to do this but afraid of the consequences.
Even I sell mobile covers in my shop from Mobile Back Covers.
Really helpful for me to explain my customers.
