주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement
필요한 것
  1. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
  2. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  3. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
  4. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement, Battery: 4 단계, 이미지 2개 중 1개 Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
  5. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the top left corner of the battery up by the black tab.
  6. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: 6 단계, 이미지 1개 중 1개
    • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
    • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
  7. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement, Power/Volume Buttons: 7 단계, 이미지 1개 중 1개
    • The volume and power buttons are joined together on a common strip, so you are replacing both simultaneously.
  8. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the black connector by pulling up using a plastic opening tool underneath the edge. This connection attaches the power/volume cable to the mother board.
  9. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the 3-mm screw holding the upper left corner of the main board using a Phillips#00 screwdriver.
  10. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: 10 단계, 이미지 2개 중 1개 Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: 10 단계, 이미지 2개 중 2개
    • Gently pry the lower edge of the cable off the plastic stud just above the stylus opening.
  11. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: 11 단계, 이미지 1개 중 1개
    • Gently pry the middle of the cable up and off of the two plastic studs.
    • Gently pry the part of the cable adjacent to the power button up and off the two plastics studs.
    • Gently pry the upper part of the cable up and off the two plastic studs.
  12. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, pull the part of the cable that is located behind the volume buttons out of the slot.
  13. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: 13 단계, 이미지 1개 중 1개
    • Hold the corner of the motherboard up and carefully slide the cable out.
결론
다른 25명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Joel
회원 가입일: 09/23/14
1,876 평판
안내서 6개를 작성함
USF Tampa, Team 12-2, Blackwell Fall 2014 USF Tampa, Team 12-2, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S12G2
4 회원들
안내서 16개를 작성함
8가이드 댓글
My wife's Samsung galaxy note 8 would not turn on. She has had it for three years and we thought it should be scrapped. I searched for this problem on line and found this site. Ordered new on off kit on e-bay. Followed these instructions. Very straight forward. Took less than 30 minutes. Reassembled and returned tablet to wife, who is very happy. Hoping for a good meal tonight! Thanks very much Joel. Martin
Martin Lonsdale - 답글
what is the part number or kit number of the on/off kit, how to order. please help.
Cesar Manila -
My Samsung Galaxy Note 8.0 (wifi only) will not switch on or respond in any way to a known-good charger being plugged into it. It hasn't had much use since new, so I don't believe it's a worn out battery or switch, but I tested those anyway. It will not reset, or hard-reset, and I have removed and tested the function of the power tact-switch, that that works fine. The battery reads 4.2V. I fear that I've bricked it. Nothing I do gives any response. Is there anything else I can try?
craig9 - 답글
Worked last night, was charged, checked charger(good), replaced charge port, replaced power/volume button, replaced battery. Not a peep out of the tablet. No battery image on screen. Tried hard reset etc. Nada. What now, trash can??? Can't see spending another 45 to 50 $$$ for mother board. Can any body prove Samsung built deliberate ob's into the tablet. Like read the software code.
louiseno36 - 답글
This is not a note 8 though
discoditto - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 129
전체 시간: 23,833
