주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 8.0 Speaker Replacement
필요한 것
  1. Samsung Galaxy Note 8.0 Speaker Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
  2. Samsung Galaxy Note 8.0 Speaker Replacement: 2 단계, 이미지 1/1
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  3. Samsung Galaxy Note 8.0 Speaker Replacement: 3 단계, 이미지 1/1
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
  4. Samsung Galaxy Note 8.0 Speaker Replacement, Battery: 4 단계, 이미지 1/2 Samsung Galaxy Note 8.0 Speaker Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
  5. Samsung Galaxy Note 8.0 Speaker Replacement: 5 단계, 이미지 1/1
    • Lift the top left corner of the battery up by the black tab.
  6. Samsung Galaxy Note 8.0 Speaker Replacement: 6 단계, 이미지 1/1
    • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
    • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
  7. Samsung Galaxy Note 8.0 Speaker Replacement, Speakers: 7 단계, 이미지 1/3 Samsung Galaxy Note 8.0 Speaker Replacement, Speakers: 7 단계, 이미지 2/3 Samsung Galaxy Note 8.0 Speaker Replacement, Speakers: 7 단계, 이미지 3/3
    • Gently pry up the connectors there is one per speaker
    • Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the connector and the board to lift the connector away from the board.
  8. Samsung Galaxy Note 8.0 Speaker Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Note 8.0 Speaker Replacement: 8 단계, 이미지 2/2
    • For each speaker remove the two 3-mm Phillips head screws using a Phillips #00 screwdriver.
  9. Samsung Galaxy Note 8.0 Speaker Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Note 8.0 Speaker Replacement: 9 단계, 이미지 2/2
    • Remove the speakers from their housing.
    • If difficult use a plastic opening tool to pry up.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Joel
회원 가입일: 09/23/14
1,868 평판
안내서 6개 작성하였습니다
USF Tampa, Team 12-2, Blackwell Fall 2014 USF Tampa, Team 12-2, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S12G2
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 20
전체 시간: 2,773
