주요 콘텐츠로 건너뛰기
Samsung Galaxy Note Edge Motherboard Replacement
필요한 것
  1. Samsung Galaxy Note Edge Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power down your device and make sure that it is turned off.
    • Place the phone with the screen facing down on a clean flat surface.
  2. Samsung Galaxy Note Edge Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Note Edge Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Note Edge Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone.
    • Remove battery by using your Supdger on the notch located directly underneath battery location.
    • During the creation of this guide, we did not have access to a battery in our device.
  3. Samsung Galaxy Note Edge Motherboard Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
    • Remove the stylus from the stylus holder.
  4. Samsung Galaxy Note Edge Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Note Edge Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Note Edge Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
    • Insert your spudger into the stylus socket and pry the midframe from the phone.
    • Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
  5. Samsung Galaxy Note Edge Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Samsung Galaxy Note Edge Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone.
    • Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
  6. Samsung Galaxy Note Edge Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Note Edge Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Note Edge Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Using your Spudger's pointed end, pry off the following leads that connect these parts to the logic board in the top left hand corner:
    • Front Facing Camera
    • AMOLED Display Screen
    • AMOLED Capacitive Screen
  7. Samsung Galaxy Note Edge Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Samsung Galaxy Note Edge Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Samsung Galaxy Note Edge Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • At the top end, gently insert pointed end of spudger underneath the motherboard.
    • Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard.
    • Remove the motherboard from the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Matt Clark
회원 가입일: 04/19/18
160 평판
안내서 1개를 작성함
Cal Poly, Team S22-G6, Maness Spring 2018 Cal Poly, Team S22-G6, Maness Spring 2018 회원
CPSU-MANESS-S18S22G6
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 3,863
