주요 콘텐츠로 건너뛰기
Samsung Galaxy Note Edge Vibrator Replacement
필요한 것
  1. Samsung Galaxy Note Edge Vibrator Replacement, Battery: 1 단계, 이미지 1/1
    • Power down your device and make sure that it is turned off.
    • Place the phone with the screen facing down on a clean flat surface.
  2. Samsung Galaxy Note Edge Vibrator Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Note Edge Vibrator Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Note Edge Vibrator Replacement: 2 단계, 이미지 3/3
    • Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone.
    • Remove battery by using your Supdger on the notch located directly underneath battery location.
    • During the creation of this guide, we did not have access to a battery in our device.
  3. Samsung Galaxy Note Edge Vibrator Replacement, Motherboard: 3 단계, 이미지 1/1
    • Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
    • Remove the stylus from the stylus holder.
  4. Samsung Galaxy Note Edge Vibrator Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Note Edge Vibrator Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Note Edge Vibrator Replacement: 4 단계, 이미지 3/3
    • Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
    • Insert your spudger into the stylus socket and pry the midframe from the phone.
    • Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
  5. Samsung Galaxy Note Edge Vibrator Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Note Edge Vibrator Replacement: 5 단계, 이미지 2/2
    • With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone.
    • Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
  6. Samsung Galaxy Note Edge Vibrator Replacement: 6 단계, 이미지 1/3 Samsung Galaxy Note Edge Vibrator Replacement: 6 단계, 이미지 2/3 Samsung Galaxy Note Edge Vibrator Replacement: 6 단계, 이미지 3/3
    • Using your Spudger's pointed end, pry off the following leads that connect these parts to the logic board in the top left hand corner:
    • Front Facing Camera
    • AMOLED Display Screen
    • AMOLED Capacitive Screen
  7. Samsung Galaxy Note Edge Vibrator Replacement: 7 단계, 이미지 1/3 Samsung Galaxy Note Edge Vibrator Replacement: 7 단계, 이미지 2/3 Samsung Galaxy Note Edge Vibrator Replacement: 7 단계, 이미지 3/3
    • At the top end, gently insert pointed end of spudger underneath the motherboard.
    • Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard.
    • Remove the motherboard from the device.
  8. Samsung Galaxy Note Edge Vibrator Replacement, Vibrator: 8 단계, 이미지 1/1
    • Insert the sharp end of the spudger underneath the golden cables connecting the vibration motor. Gently pry upwards to disconnect them.
  9. Samsung Galaxy Note Edge Vibrator Replacement: 9 단계, 이미지 1/3 Samsung Galaxy Note Edge Vibrator Replacement: 9 단계, 이미지 2/3 Samsung Galaxy Note Edge Vibrator Replacement: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Insert one end of the Tweezers into said notch. Pry upwards and grab the round piece to remove the vibration motor.
    • Adhesive holds the motor in place, so force is required to break this bond.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Duc Huynh
회원 가입일: 04/19/18
253 평판
안내서 2개 작성하였습니다
Cal Poly, Team S22-G6, Maness Spring 2018 Cal Poly, Team S22-G6, Maness Spring 2018 회원
CPSU-MANESS-S18S22G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 436
