주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Use this guide to replace or remove e front-facing camera from a Samsung Galaxy Note II.
  1. Grasp the end of the stylus and remove it from its slot in the midframe. Grasp the end of the stylus and remove it from its slot in the midframe.
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot. Remove the microSD card.
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward. Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Remove the battery from the midframe.
    • Remove the battery from the midframe.
  7. Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone. Slide the plastic opening tool down the seam. Slide the plastic opening tool down the seam.
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Continue to run the plastic opening tool down the seam. Continue to run the plastic opening tool down the seam. Continue to run the plastic opening tool down the seam.
    • Continue to run the plastic opening tool down the seam.
  10. Carefully pry around the corner with a plastic opening tool. Carefully pry around the corner with a plastic opening tool.
    • Carefully pry around the corner with a plastic opening tool.
  11. Pry along the top of the phone with a plastic opening tool. Pry along the top of the phone with a plastic opening tool.
    • Pry along the top of the phone with a plastic opening tool.
  12. Push the plastic opening tool down to free the corner of the midframe from the display assembly. Push the plastic opening tool down to free the corner of the midframe from the display assembly.
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Free the clips along the power button side of the phone. Lastly, free the two clips along the top and bottom edge of battery compartment.
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Lift the display assembly out of the midframe. Lift the display assembly out of the midframe.
    • Lift the display assembly out of the midframe.
  15. Remove the 3mm Phillips #00 screw from the front-facing camera bracket.
    • Remove the 3mm Phillips #00 screw from the front-facing camera bracket.
  16. Remove the front-facing camera bracket.
    • Remove the front-facing camera bracket.
  17. Use the flat end of a spudger to disconnect the front-facing camera connector.
    • Use the flat end of a spudger to disconnect the front-facing camera connector.
  18. Remove the front-facing camera.
    • Remove the front-facing camera.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 2012년 10월 18일
422,757 평판
안내서 547개 작성하였습니다
iFixit iFixit 회원
Community
129 회원들
안내서 12,922개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 11,335
