주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note II Midframe Replacement
필요한 것
  1. Samsung Galaxy Note II Midframe Replacement, Stylus: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Midframe Replacement, Stylus: 1 단계, 이미지 2개 중 2개
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Midframe Replacement, Rear Case: 2 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Midframe Replacement, Rear Case: 2 단계, 이미지 2개 중 2개
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Midframe Replacement: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Note II Midframe Replacement: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Note II Midframe Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Midframe Replacement, MicroSD Card: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Note II Midframe Replacement, MicroSD Card: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Note II Midframe Replacement, MicroSD Card: 4 단계, 이미지 3개 중 3개
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Midframe Replacement, Battery: 5 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Midframe Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Midframe Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Midframe Replacement, Midframe: 7 단계, 이미지 1개 중 1개
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Midframe Replacement: 8 단계, 이미지 3개 중 1개 Samsung Galaxy Note II Midframe Replacement: 8 단계, 이미지 3개 중 2개 Samsung Galaxy Note II Midframe Replacement: 8 단계, 이미지 3개 중 3개
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Midframe Replacement: 9 단계, 이미지 3개 중 1개 Samsung Galaxy Note II Midframe Replacement: 9 단계, 이미지 3개 중 2개 Samsung Galaxy Note II Midframe Replacement: 9 단계, 이미지 3개 중 3개
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Midframe Replacement: 10 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Midframe Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Midframe Replacement: 11 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Midframe Replacement: 11 단계, 이미지 2개 중 2개
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Midframe Replacement: 12 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Midframe Replacement: 12 단계, 이미지 2개 중 2개
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Midframe Replacement: 13 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Midframe Replacement: 13 단계, 이미지 2개 중 2개
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Midframe Replacement: 14 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Midframe Replacement: 14 단계, 이미지 2개 중 2개
    • Lift the display assembly out of the midframe.
결론
다른 52명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
477,236 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,686개를 작성함
5가이드 댓글
There are two hidden clips near battery housing. One inside in upper part of battery housing and the second below battery near antenna.
milankerslager - 답글 공유
How do I fix the glass
Nena Summer Perez - 답글 공유
Very good job you are doing. It is very helpful to us. Thanks for sharing your knowledge to the people my wishes are with you god bless you.
HARDIK PANCHOLI - 답글 공유
very very very useful brother
Arunkrishna T H - 답글 공유
Brilliant Thanks.
michaeleggar6 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 84
전체 시간: 31,249
