주요 콘텐츠로 건너뛰기
Samsung Galaxy Note II Rear Facing Camera Assembly Replacement
필요한 것
  1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Stylus: 1 단계, 이미지 1/2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Stylus: 1 단계, 이미지 2/2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Rear Case: 2 단계, 이미지 1/2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Rear Case: 2 단계, 이미지 2/2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 3 단계, 이미지 3/3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, MicroSD Card: 4 단계, 이미지 1/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, MicroSD Card: 4 단계, 이미지 2/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, MicroSD Card: 4 단계, 이미지 3/3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Battery: 5 단계, 이미지 1/2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Battery: 5 단계, 이미지 2/2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 6 단계, 이미지 1/1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Midframe: 7 단계, 이미지 1/1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 8 단계, 이미지 1/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 8 단계, 이미지 2/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 8 단계, 이미지 3/3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 9 단계, 이미지 1/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 9 단계, 이미지 2/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 9 단계, 이미지 3/3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 10 단계, 이미지 2/2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 11 단계, 이미지 1/2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 11 단계, 이미지 2/2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 12 단계, 이미지 1/2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 12 단계, 이미지 2/2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 13 단계, 이미지 1/2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 13 단계, 이미지 2/2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 14 단계, 이미지 1/2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 14 단계, 이미지 2/2
    • Lift the display assembly out of the midframe.
  15. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Motherboard Assembly: 15 단계, 이미지 1/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Motherboard Assembly: 15 단계, 이미지 2/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Motherboard Assembly: 15 단계, 이미지 3/3
    • Use a spudger to disconnect the vibrator/power button assembly cable connector.
    • Disconnect the antenna cable connector.
    • Disconnect the display cable connector.
  16. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 16 단계, 이미지 1/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 16 단계, 이미지 2/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 16 단계, 이미지 3/3
    • Disconnect the front-facing camera cable connector.
    • Disconnect the headphone jack cable connector.
    • Disconnect the digitizer cable connector.
  17. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 17 단계, 이미지 1/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 17 단계, 이미지 2/3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 17 단계, 이미지 3/3
    • Use the spudger to disconnect the antenna cable connector from the motherboard.
    • Disconnect the soft button cable connector.
    • Disconnect the USB board cable connector.
  18. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 18 단계, 이미지 1/1
    • Remove the 3 mm Phillips #00 screw securing the motherboard to the display assembly.
  19. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 19 단계, 이미지 1/2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 19 단계, 이미지 2/2
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
  20. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Rear Facing Camera Assembly: 20 단계, 이미지 1/1
    • Use a spudger to disconnect the rear-facing camera assembly cable connector.
  21. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 21 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers, or your fingers, to remove the rear-facing camera assembly.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,958 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,292개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 17
전체 시간: 12,103
