주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note II Speaker Enclosure Replacement
필요한 것
    1. Samsung Galaxy Note II Speaker Enclosure Replacement, Stylus: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Speaker Enclosure Replacement, Stylus: 1 단계, 이미지 2개 중 2개
      • Grasp the end of the stylus and remove it from its slot in the midframe.
      댓글 쓰기
    1. Samsung Galaxy Note II Speaker Enclosure Replacement, Rear Case: 2 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Speaker Enclosure Replacement, Rear Case: 2 단계, 이미지 2개 중 2개
      • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
      댓글 쓰기
    2. Samsung Galaxy Note II Speaker Enclosure Replacement: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Note II Speaker Enclosure Replacement: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Note II Speaker Enclosure Replacement: 3 단계, 이미지 3개 중 3개
      • Lift the rear case by the corner nearest the divot and remove it from the phone.
      댓글 쓰기
    1. Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: 4 단계, 이미지 3개 중 3개
      • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • Remove the microSD card.
      • For reassembly, push the microSD card into the slot until it clicks in place.
      댓글 쓰기
    1. Samsung Galaxy Note II Speaker Enclosure Replacement, Battery: 5 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Speaker Enclosure Replacement, Battery: 5 단계, 이미지 2개 중 2개
      • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
      댓글 쓰기
    2. Samsung Galaxy Note II Speaker Enclosure Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the battery from the midframe.
      댓글 쓰기
    1. Samsung Galaxy Note II Speaker Enclosure Replacement, Midframe: 7 단계, 이미지 1개 중 1개
      • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
      댓글 쓰기
    2. Samsung Galaxy Note II Speaker Enclosure Replacement: 8 단계, 이미지 3개 중 1개 Samsung Galaxy Note II Speaker Enclosure Replacement: 8 단계, 이미지 3개 중 2개 Samsung Galaxy Note II Speaker Enclosure Replacement: 8 단계, 이미지 3개 중 3개
      • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
      • Slide the plastic opening tool down the seam.
      댓글 쓰기
    3. Samsung Galaxy Note II Speaker Enclosure Replacement: 9 단계, 이미지 3개 중 1개 Samsung Galaxy Note II Speaker Enclosure Replacement: 9 단계, 이미지 3개 중 2개 Samsung Galaxy Note II Speaker Enclosure Replacement: 9 단계, 이미지 3개 중 3개
      • Continue to run the plastic opening tool down the seam.
      댓글 쓰기
    4. Samsung Galaxy Note II Speaker Enclosure Replacement: 10 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Speaker Enclosure Replacement: 10 단계, 이미지 2개 중 2개
      • Carefully pry around the corner with a plastic opening tool.
      댓글 쓰기
    5. Samsung Galaxy Note II Speaker Enclosure Replacement: 11 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Speaker Enclosure Replacement: 11 단계, 이미지 2개 중 2개
      • Pry along the top of the phone with a plastic opening tool.
      댓글 쓰기
    6. Samsung Galaxy Note II Speaker Enclosure Replacement: 12 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Speaker Enclosure Replacement: 12 단계, 이미지 2개 중 2개
      • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
      댓글 쓰기
    7. Samsung Galaxy Note II Speaker Enclosure Replacement: 13 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Speaker Enclosure Replacement: 13 단계, 이미지 2개 중 2개
      • Free the clips along the power button side of the phone.
      • Lastly, free the two clips along the top and bottom edge of battery compartment.
      댓글 쓰기
    8. Samsung Galaxy Note II Speaker Enclosure Replacement: 14 단계, 이미지 2개 중 1개 Samsung Galaxy Note II Speaker Enclosure Replacement: 14 단계, 이미지 2개 중 2개
      • Lift the display assembly out of the midframe.
      댓글 쓰기
    1. Samsung Galaxy Note II Speaker Enclosure Replacement, Speaker Enclosure: 15 단계, 이미지 1개 중 1개
      • Remove the 3 mm Phillips #00 screw from the speaker enclosure.
      댓글 쓰기
    2. Samsung Galaxy Note II Speaker Enclosure Replacement: 16 단계, 이미지 1개 중 1개
      • Remove the speaker enclosure.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
478,260 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 86,241개를 작성함
1가이드 댓글
This is an awesome guide! Cheers Sam. I have never done any electrical fixes before so I was a phone fixing virgin. I bought both the tools and the speaker for £5.80 on ebay, followed your guide carefully and had no problems. It was an easy process. Thanks to the confidence I had in your guide I didn’t have to go and buy a new phone so you saved me the £180 I thought I was going to have to spend!
Cheers, Nick (UK)
Nick Village - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 31
지난 30일: 70
전체 시간: 14,647
