주요 콘텐츠로 건너뛰기
Samsung Galaxy Note Pro 12.2 Audio Jack Replacement
필요한 것
  1. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement, Audio Jack: 1 단계, 이미지 1/1
    • Make sure that your device is powered off before starting your repair.
    • Carefully remove the back cover with the blue opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 2 단계, 이미지 2/2
    • Remove the two 3mm Phillips #00 screws securing in the white cover over the audio jack.
  3. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 3 단계, 이미지 1/1
    • Remove the white cover over the audio jack with the plastic opening tool by pushing up on the black connecter.
  4. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 4 단계, 이미지 2/2
    • Remove the two 3mm Phillips #00 screws over the silver cover.
    • The silver cover is attached to the whole audio jack; do not try to pull this away by itself.
  5. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 5 단계, 이미지 2/2
    • Pop up the green connecter by gently pulling up.
  6. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 6 단계, 이미지 2/2
    • Pull up on the circular amp with the spudger tool to release it from the device.
  7. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 7 단계, 이미지 1/1
    • Remove the whole audio jack by pulling gently up on the copper piece.
    • This component is extremely fragile.
결론
Tina Kong
회원 가입일: 09/22/17
1,278 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 659
