주요 콘텐츠로 건너뛰기
Samsung Galaxy Note Pro 12.2 Motherboard Replacement
필요한 것
  1. Samsung Galaxy Note Pro 12.2 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Remove the back cover with the blue plastic opening tool.
  2. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 2 단계, 이미지 2/2
    • Disconnect the five base connectors from the motherboard by using the blue opening tool to carefully remove the connectors.
  3. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the yellow tape on the ribbon cables before attempting to disconnect them from the motherboard.
    • Using the blue opening tool, pry on the black tab at the base connector of ribbon cables until it is flipped up and moves with ease. Then, pull the ribbon cable from the base connectors of the motherboard.
  4. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 4 단계, 이미지 2/2
    • Potential damage to the motherboard could occur without supporting the black motherboard connector as the white cable connector is being removed.
    • Remove the power cable from the motherboard by prying slightly on both sides of the clip using tweezers.
  5. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove all three of the 3.0 mm screws using the Phillips #00 screwdriver.
    • It is easiest to pry on the points depicted in the pictures for the next step.
    • Use the blue plastic opening tool to pry the speakers up from the clips that hold them in place.
  6. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the motherboard using the blue opening tool while keeping any wires and connectors out of the way.
    • The motherboard should come out freely.
결론
다른 2명이 해당 안내서를 완성하였습니다.
La'Taja Long
회원 가입일: 11/04/19
346 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G3, Henning Fall 2019 IUPUI, Team S1-G3, Henning Fall 2019 회원
IUPUI-HENNING-F19S1G3
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
Hi. Can i install sm-p905 motherboard into my sm-p900?
yem44 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 18
전체 시간: 2,097
