주요 콘텐츠로 건너뛰기
Samsung Galaxy Note Pro 12.2 SD Port Replacement
필요한 것
  1. Samsung Galaxy Note Pro 12.2 SD Port Replacement, SD Port: 1 단계, 이미지 1/1
    • Turn off your device before starting your repair.
    • Carefully remove the back cover with the plastic opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 SD Port Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: 2 단계, 이미지 2/2
    • Pop up the orange tab connected to the SD port with the plastic opening tool.
  3. Samsung Galaxy Note Pro 12.2 SD Port Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: 3 단계, 이미지 2/2
    • Remove the one 3mm Phillips #00 screw connected to the SD port.
  4. Samsung Galaxy Note Pro 12.2 SD Port Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: 4 단계, 이미지 2/2
    • Pop open the orange wire tab connected to the SD port with the plastic opening tool.
    • If there is tape covering your tab, remove it with the tweezers before you pop open the tab.
  5. Samsung Galaxy Note Pro 12.2 SD Port Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: 5 단계, 이미지 2/2
    • Using the orange tab, pull the SD port up and away from the device.
  6. Samsung Galaxy Note Pro 12.2 SD Port Replacement: 6 단계, 이미지 1/1
    • Using the plastic end of the tweezers pop up the orange tab connecting the SD port to the device.
    • There is a little indent below the orange tab to help get under this piece. It may be difficult to remove, push up hard.
결론
Tina Kong
회원 가입일: 09/22/17
1,278 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 486
