주요 콘텐츠로 건너뛰기
Samsung Galaxy Note Pro 12.2 Speakers Replacement
필요한 것
  1. Samsung Galaxy Note Pro 12.2 Speakers Replacement, Speakers: 1 단계, 이미지 1/1
    • Make sure the device is powered off before starting repair.
    • Carefully remove the back cover with the blue opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 Speakers Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 Speakers Replacement: 2 단계, 이미지 2/2
    • Remove the one 3mm Phillips #00 screw securing the black speaker.
  3. Samsung Galaxy Note Pro 12.2 Speakers Replacement: 3 단계, 이미지 1/1
    • Using the plastic opening tool, pop the black speaker up and away from the device.
  4. Samsung Galaxy Note Pro 12.2 Speakers Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 Speakers Replacement: 4 단계, 이미지 2/2
    • Remove the two 3mm screws securing the white speaker with the Phillips #00 screwdriver.
  5. Samsung Galaxy Note Pro 12.2 Speakers Replacement: 5 단계, 이미지 1/1
    • Using the blue opening tool pop the white speaker up and away from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tina Kong
회원 가입일: 09/22/17
1,278 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 442
