주요 콘텐츠로 건너뛰기
Samsung Galaxy Note Pro 12.2 USB Port Replacement
필요한 것
  1. Samsung Galaxy Note Pro 12.2 USB Port Replacement, USB Port: 1 단계, 이미지 1/1
    • Make sure the device is off before starting your repair.
    • Carefully remove the back cover with the plastic opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 USB Port Replacement: 2 단계, 이미지 1/1
    • Using your finger, push up on the clip to disconnect from the device.
  3. Samsung Galaxy Note Pro 12.2 USB Port Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 USB Port Replacement: 3 단계, 이미지 2/2
    • Remove the two 3mm screws from the silver cover using the Phillips #00 screwdriver.
  4. Samsung Galaxy Note Pro 12.2 USB Port Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 USB Port Replacement: 4 단계, 이미지 2/2
    • Pop open the orange tab that is connected to the SD port using the plastic opening tool.
  5. Samsung Galaxy Note Pro 12.2 USB Port Replacement: 5 단계, 이미지 1/1
    • Pop up the USB port with the plastic opening tool.
    • Make sure that you are pushing up from underneath the part and not placing the tool inside the USB port itself.
  6. Samsung Galaxy Note Pro 12.2 USB Port Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Note Pro 12.2 USB Port Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool, carefully lift away the orange piece connected to the USB port.
    • This piece is glued down. Be careful as you peel it away from the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Tina Kong
회원 가입일: 09/22/17
1,278 평판
안내서 5개 작성하였습니다
댓글 5개
I have a problem with my note pro 12.2 wifi. The battery connector is broken and needs to be replaced on the motherboard. I want to do it right but can find No information online about removing the motherboard (I have found one that is very good for the 10.1) but there are cables on the 12.2 not on the 10.1 that I am not sure how to remove them.
Wayne De Groot - 답글
How about a battery connector replacement for the note pro 12.2 SM-P900 on motherboard.
Wayne De Groot - 답글
Great instruction set and photos. I was a little nervous cracking it open for the first time (not as bad as the first time I upgraded my PC, but close), but your pictures and instructions were aces! It would have gone easier if I’d realized earlier that clicking on the photos popped them out to a separate tab where I could zoom, but I figured that out soon enough. The general concensus on the opener tools are that they don’t last long. I’d have to agree with that. Mine took a beating trying to get the back off, but with your instructions, it’s fixed. Thanks!
Carol Lapp - 답글
I lost the two screws. What size are they and where can I purchase them? Thank you.
Russell Ichenberg - 답글
very good instructions, was very helpful.
But it's still makes trouble charging.
Can it be any other problem or reason? Something doing the opposite of loading, very frustrating.
Daniela Chrzanowski - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 4,109
