소개
Use this guide to restore silent rings to your Samsung Galaxy Note by replacing the vibrator.
부품
부품은 필요하지 않습니다.
Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
Insert your finger in the notch of the battery compartment.
Press the battery toward the rear facing camera while pulling outward.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
Use the flat end of a spudger to carefully disconnect the display cable connector.
Insert the tip of a spudger under the vibrator connector cable near the contacts then slide it toward the vibrator itself.
다른 7명이 해당 안내서를 완성하였습니다.
