주요 콘텐츠로 건너뛰기
Samsung Galaxy Note Vibrator Replacement
필요한 것
  1. Samsung Galaxy Note Vibrator Replacement, Stylus: 1 단계, 이미지 1/2 Samsung Galaxy Note Vibrator Replacement, Stylus: 1 단계, 이미지 2/2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note Vibrator Replacement, Rear Case: 2 단계, 이미지 1/2 Samsung Galaxy Note Vibrator Replacement, Rear Case: 2 단계, 이미지 2/2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note Vibrator Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Note Vibrator Replacement: 3 단계, 이미지 2/2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note Vibrator Replacement, Battery: 4 단계, 이미지 1/2 Samsung Galaxy Note Vibrator Replacement, Battery: 4 단계, 이미지 2/2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note Vibrator Replacement, MicroSD Card: 5 단계, 이미지 1/3 Samsung Galaxy Note Vibrator Replacement, MicroSD Card: 5 단계, 이미지 2/3 Samsung Galaxy Note Vibrator Replacement, MicroSD Card: 5 단계, 이미지 3/3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note Vibrator Replacement: 6 단계, 이미지 1/1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note Vibrator Replacement, SIM Card: 7 단계, 이미지 1/2 Samsung Galaxy Note Vibrator Replacement, SIM Card: 7 단계, 이미지 2/2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note Vibrator Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Note Vibrator Replacement: 8 단계, 이미지 2/2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note Vibrator Replacement, Midframe: 9 단계, 이미지 1/1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note Vibrator Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Note Vibrator Replacement: 10 단계, 이미지 2/2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note Vibrator Replacement: 11 단계, 이미지 1/3 Samsung Galaxy Note Vibrator Replacement: 11 단계, 이미지 2/3 Samsung Galaxy Note Vibrator Replacement: 11 단계, 이미지 3/3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note Vibrator Replacement: 12 단계, 이미지 1/3 Samsung Galaxy Note Vibrator Replacement: 12 단계, 이미지 2/3 Samsung Galaxy Note Vibrator Replacement: 12 단계, 이미지 3/3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note Vibrator Replacement: 13 단계, 이미지 1/2 Samsung Galaxy Note Vibrator Replacement: 13 단계, 이미지 2/2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note Vibrator Replacement, Motherboard Assembly: 14 단계, 이미지 1/2 Samsung Galaxy Note Vibrator Replacement, Motherboard Assembly: 14 단계, 이미지 2/2
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  15. Samsung Galaxy Note Vibrator Replacement: 15 단계, 이미지 1/3 Samsung Galaxy Note Vibrator Replacement: 15 단계, 이미지 2/3 Samsung Galaxy Note Vibrator Replacement: 15 단계, 이미지 3/3
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  16. Samsung Galaxy Note Vibrator Replacement: 16 단계, 이미지 1/3 Samsung Galaxy Note Vibrator Replacement: 16 단계, 이미지 2/3 Samsung Galaxy Note Vibrator Replacement: 16 단계, 이미지 3/3
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  17. Samsung Galaxy Note Vibrator Replacement: 17 단계, 이미지 1/1
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  18. Samsung Galaxy Note Vibrator Replacement: 18 단계, 이미지 1/2 Samsung Galaxy Note Vibrator Replacement: 18 단계, 이미지 2/2
    • Remove the motherboard assembly from the display assembly.
  19. Samsung Galaxy Note Vibrator Replacement, Vibrator: 19 단계, 이미지 1/3 Samsung Galaxy Note Vibrator Replacement, Vibrator: 19 단계, 이미지 2/3 Samsung Galaxy Note Vibrator Replacement, Vibrator: 19 단계, 이미지 3/3
    • Insert the tip of a spudger under the vibrator connector cable near the contacts then slide it toward the vibrator itself.
  20. Samsung Galaxy Note Vibrator Replacement: 20 단계, 이미지 1/2 Samsung Galaxy Note Vibrator Replacement: 20 단계, 이미지 2/2
    • Insert the flat end of a spudger under the vibrator connector cable and pry it up from the adhesive.
  21. Samsung Galaxy Note Vibrator Replacement: 21 단계, 이미지 1/1
    • Remove the vibrator from the display assembly.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
467,548 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,077개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 6,152
