주요 콘텐츠로 건너뛰기
Samsung Galaxy Note10 Wireless Charging Coil Replacement
필요한 것
  1. Samsung Galaxy Note10 Wireless Charging Coil Replacement, Heat the back panel: 1 단계, 이미지 1/1
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy Note10 Wireless Charging Coil Replacement, Insert an opening pick: 2 단계, 이미지 1/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement, Insert an opening pick: 2 단계, 이미지 2/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement, Insert an opening pick: 2 단계, 이미지 3/3
    • Apply a suction cup to the heated edge of the back panel, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Samsung Galaxy Note10 Wireless Charging Coil Replacement, Begin to slice the adhesive: 3 단계, 이미지 1/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement, Begin to slice the adhesive: 3 단계, 이미지 2/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement, Begin to slice the adhesive: 3 단계, 이미지 3/3
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Do not insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note10 Wireless Charging Coil Replacement, Slice the left side adhesive: 4 단계, 이미지 1/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement, Slice the left side adhesive: 4 단계, 이미지 2/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement, Slice the left side adhesive: 4 단계, 이미지 3/3
    • Insert a second opening pick and slide it across the left side towards the top left corner to slice the adhesive.
    • Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
  5. Samsung Galaxy Note10 Wireless Charging Coil Replacement, Slice the top side adhesive: 5 단계, 이미지 1/1
    • Prepare an iOpener and apply it to the top edge of the phone for one minute.
  6. Samsung Galaxy Note10 Wireless Charging Coil Replacement: 6 단계, 이미지 1/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement: 6 단계, 이미지 2/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement: 6 단계, 이미지 3/3
    • Insert a third opening pick into the gap on the top edge of the phone.
    • Slide the opening pick to the top right corner, slicing the adhesive.
    • Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
  7. Samsung Galaxy Note10 Wireless Charging Coil Replacement, Slice the right side adhesive: 7 단계, 이미지 1/1
    • Prepare an iOpener and apply it to the right edge of the phone for one minute.
  8. Samsung Galaxy Note10 Wireless Charging Coil Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Note10 Wireless Charging Coil Replacement: 8 단계, 이미지 2/2
    • Insert a fourth and final opening pick into the gap on the right side of the phone, sliding it down towards the bottom right corner of the phone to slice the adhesive.
    • The back panel will begin to separate from the phone as you get closer to the bottom edge.
    • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
  9. Samsung Galaxy Note10 Wireless Charging Coil Replacement, Lift off the back panel: 9 단계, 이미지 1/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement, Lift off the back panel: 9 단계, 이미지 2/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement, Lift off the back panel: 9 단계, 이미지 3/3
    • Lift up and remove the back panel.
  10. Samsung Galaxy Note10 Wireless Charging Coil Replacement, Lift up the metal cover: 10 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
  11. Samsung Galaxy Note10 Wireless Charging Coil Replacement: 11 단계, 이미지 1/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement: 11 단계, 이미지 2/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement: 11 단계, 이미지 3/3
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
  12. Samsung Galaxy Note10 Wireless Charging Coil Replacement, Disconnect the battery: 12 단계, 이미지 1/2 Samsung Galaxy Note10 Wireless Charging Coil Replacement, Disconnect the battery: 12 단계, 이미지 2/2
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
  13. Samsung Galaxy Note10 Wireless Charging Coil Replacement, Disconnect the wireless charging coil: 13 단계, 이미지 1/2 Samsung Galaxy Note10 Wireless Charging Coil Replacement, Disconnect the wireless charging coil: 13 단계, 이미지 2/2
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
  14. Samsung Galaxy Note10 Wireless Charging Coil Replacement, Remove the wireless charging coil: 14 단계, 이미지 1/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement, Remove the wireless charging coil: 14 단계, 이미지 2/3 Samsung Galaxy Note10 Wireless Charging Coil Replacement, Remove the wireless charging coil: 14 단계, 이미지 3/3
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
다른 4명이 해당 안내서를 완성하였습니다.
Carsten Frauenheim
회원 가입일: 03/10/20
113,715 평판
안내서 338개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 31
30일 전: 180
전체 시간: 8,299
