주요 콘텐츠로 건너뛰기
소개
Samsung Galaxy Note 5 LCD screen replacement, USB board replacement and Home button flex replacement share the most same and complicated steps, so bring them together.
동영상 개요
  1. Remove SIM card tray and S pen. Remove SIM card tray and S pen.
    • Remove SIM card tray and S pen.
  2. Remove back cover. Remove back cover. Remove back cover.
    • Remove back cover.
  3. Remove middle housing. Remove middle housing. Remove middle housing.
    • Remove middle housing.
  4. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  5. Remove battery. Remove battery. Remove battery.
    • Remove battery.
  6. Release connectors on the motherboard. Release connectors on the motherboard. Release connectors on the motherboard.
    • Release connectors on the motherboard.
  7. Release USB board connector on the back and remove the motherboard. Release USB board connector on the back and remove the motherboard. Release USB board connector on the back and remove the motherboard.
    • Release USB board connector on the back and remove the motherboard.
  8. Remove LCD screen. It's really difficult, see more details on Samsung Galaxy Note 5 teardown. Remove LCD screen. It's really difficult, see more details on Samsung Galaxy Note 5 teardown. Remove LCD screen. It's really difficult, see more details on Samsung Galaxy Note 5 teardown.
  9. Remove USB board. If you replace USB board only, please be careful with the LCD screen very much. Once a defect, the screen will be cracked or broken. Remove USB board. If you replace USB board only, please be careful with the LCD screen very much. Once a defect, the screen will be cracked or broken. Remove USB board. If you replace USB board only, please be careful with the LCD screen very much. Once a defect, the screen will be cracked or broken.
    • Remove USB board. If you replace USB board only, please be careful with the LCD screen very much. Once a defect, the screen will be cracked or broken.
  10. Push the button out from slot as the direction of mark. And then release the adhesive and remove button flex. The same tips: Be careful with the LCD screen! The same tips: Be careful with the LCD screen!
    • Push the button out from slot as the direction of mark. And then release the adhesive and remove button flex.
    • The same tips: Be careful with the LCD screen!
결론
다른 72명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 2014년 03월 25일
41,964 평판
안내서 62개 작성하였습니다
hola que debo hacer si en la pantalla amoled de mi galaxy note 5 se visualiza una mancha morada y al medio negro que se esta expandiendo por toda la pantalla y al colocarlo contra la luz se visualiza internamente una rajadura lo cual no me permita utilizar correctamente el teclado para escribir mensajes.
jorge - 답글
me paso exactamente lo mismo...
solucionaste tu problema?
eselemichrisvega25 -
Cambiarla, esta internamente dañada.
msantanamontero - 답글
Do I have o replace the lcd screen if my front screen has black marks
platinummom1 - 답글
Lol that question was answered previously in Spanish (its just funny to me), but yes, it has internal damage, change the screen.
ninoabigail96 -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 33
지난 30일: 171
전체 시간: 147,334
