소개
Broken power button? Use this guide to remove the power button on your Galaxy Note 5. The guide will take you through the steps of removing the back glass, separating the middle housing and removing the necessary parts to remove the power button.
필요한 것
Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
Press down until the SIM Card Tray begins to protrude out of the device.
Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
While pulling upwards, insert a pick under the rear glass
다른 한 분이 해당 안내서를 완성하였습니다.
