주요 콘텐츠로 건너뛰기
Samsung Galaxy Note5 Volume Button Replacement
필요한 것
  1. Samsung Galaxy Note5 Volume Button Replacement, SIM Card Tray: 1 단계, 이미지 1/1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Volume Button Replacement: 2 단계, 이미지 1/1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Volume Button Replacement, Power Button: 3 단계, 이미지 1/1
    • Heat the back of the device with a heat gun for 2 minutes
  4. Samsung Galaxy Note5 Volume Button Replacement: 4 단계, 이미지 1/1
    • Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
    • Be careful holding the device after heating the back, it may burn!
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Volume Button Replacement: 5 단계, 이미지 1/1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Volume Button Replacement: 6 단계, 이미지 1/1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Volume Button Replacement: 7 단계, 이미지 1/1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Volume Button Replacement: 8 단계, 이미지 1/1
    • Remove the S-Pen from the bottom of the device
  9. Samsung Galaxy Note5 Volume Button Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Note5 Volume Button Replacement: 9 단계, 이미지 2/2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Volume Button Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Note5 Volume Button Replacement: 10 단계, 이미지 2/2
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Volume Button Replacement: 11 단계, 이미지 1/2 Samsung Galaxy Note5 Volume Button Replacement: 11 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Loosen the power button flex adhesive by holding it with the tweezers.
    • With the tweezers, pry up and remove the power button flex
  12. Samsung Galaxy Note5 Volume Button Replacement: 12 단계, 이미지 1/1
    • Push out the power button with the tip of the tweezers.
  13. Samsung Galaxy Note5 Volume Button Replacement, Volume Button: 13 단계, 이미지 1/2 Samsung Galaxy Note5 Volume Button Replacement, Volume Button: 13 단계, 이미지 2/2
    • Loosen the volume flex adhesive.
    • Pry up and remove the volume button flex.
  14. Samsung Galaxy Note5 Volume Button Replacement: 14 단계, 이미지 1/1
    • Push out the volume button and remove it from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Bernice Nunez
회원 가입일: 04/19/18
340 평판
안내서 2개 작성하였습니다
Cal Poly, Team S25-G17, Maness Spring 2018 Cal Poly, Team S25-G17, Maness Spring 2018 회원
CPSU-MANESS-S18S25G17
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 18
전체 시간: 1,261
