주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Broken volume button? Use this guide to remove the volume button on your Galaxy Note 5. The guide will take you through the steps of removing the back glass, separating the middle housing and removing the necessary parts to remove the volume button.
  1. Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Remove the SIM Card Tray from the slot.
    • Remove the SIM Card Tray from the slot.
  3. Heat the back of the device with a heat gun for 2 minutes
    • Heat the back of the device with a heat gun for 2 minutes
  4. Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
    • Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
    • Be careful holding the device after heating the back, it may burn!
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  7. Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  8. Once all adhesive has been cut, gently lift up the rear glass to remove it.
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  9. Remove the S-Pen from the bottom of the device
    • Remove the S-Pen from the bottom of the device
  10. Remove 20 5mm screws with a Phillips #1 Screwdriver. Remove 20 5mm screws with a Phillips #1 Screwdriver.
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  11. Grip the back of the device and press down on the white square to remove the middle housing. Grip the back of the device and press down on the white square to remove the middle housing.
    • Grip the back of the device and press down on the white square to remove the middle housing.
  12. Loosen the power button flex adhesive by holding it with the tweezers. With the tweezers, pry up and remove the power button flex
    • Loosen the power button flex adhesive by holding it with the tweezers.
    • With the tweezers, pry up and remove the power button flex
  13. Push out the power button with the tip of the tweezers.
    • Push out the power button with the tip of the tweezers.
  14. Loosen the volume flex adhesive. Pry up and remove the volume button flex.
    • Loosen the volume flex adhesive.
    • Pry up and remove the volume button flex.
  15. Push out the volume button and remove it from the device.
    • Push out the volume button and remove it from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bernice Nunez
회원 가입일: 2018년 04월 19일
295 평판
안내서 2개 작성하였습니다
Cal Poly, Team S25-G17, Maness Spring 2018 Cal Poly, Team S25-G17, Maness Spring 2018 회원
CPSU-MANESS-S18S25G17
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 750
