이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
Press down until the SIM Card Tray begins to protrude out of the device.
Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
While pulling upwards, insert a pick under the rear glass
Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
Once all adhesive has been cut, gently lift up the rear glass to remove it.
Grip the back of the device and press down on the white square to remove the middle housing.
Loosen the power button flex adhesive by holding it with the tweezers.
With the tweezers, pry up and remove the power button flex
Loosen the volume flex adhesive.
Pry up and remove the volume button flex.
다른 2명이 해당 안내서를 완성하였습니다.
