필요한 것
동영상 개요
다른 12명이 해당 안내서를 완성하였습니다.
댓글 9개
Is there a way to replace the rear camera glass without remove the back cover?
Steve Tran - 답글
Steve, I'm not sure if anyone told you yet, but yes. Using some pointed tweezers (CAREFULLY) you can pull the glass off. But, be very careful as the housing holding the glass can be damaged due to the tweezers.
Kelby -
I accidently fell my phone into the water n my front camera is enter some water.Then ,I try to dry it by my hair dryer but my front camera is cover by distilled water.The front camera is working but it is blurry. How can I fix it?
Please anyone, I have the same problem. Front cam is covered with oil. Any suggestion?
