소개
손상된 마더보드는 보조 부품 및 전원 오작동의 이유가 될 수 있습니다. 마더보드가 문제의 원인이라고 생각되면, 이 안내서를 따라서 Samsung Galaxy Note9 마더보드를 교체하세요.
필요한 것
분해를 시작하기 전에 휴대폰의 전원을 끄세요.
헤어드라이어, 열선총을 사용하거나 iOpener를 준비하여 휴대폰 후면의 오른편 가장자리에 약 1분 동안 적용하여 아랫면의 접착제를 부드럽게 하세요.
If using an iOpener it will need to be fully heated and set on for at least 5 minutes. You’ll know the phone is hot enough when its almost too hot to touch.
Just came here to say exactly that. The instructions should be amended to state that: "Get it fully hot and leave it there for at least three minutes solid."
후면 커버에 흡입 손잡이를 부착하세요.
흡입 손잡이로 들어 올려 후면 커버와 휴대폰 프레임 사이에 틈을 만드세요.
틈에 여는 픽을 끼우세요.
It takes so much heat that it is concerning that damage might be caused to the internal parts. It is difficult to heat the glue, pull the case apart and insert the pick at same time. May need some more pointers to handle these situations first, to prevent possible damage. Also what about the glue that is heated and then cooled before opening? Does it run inside and cause greater adhesion after it cools? Another thing, the handling may cause the phone to turn back on while working to separate. Don't know that that is of concern.
휴대폰의 나머지 부분보다 상단 가장자리와 카메라 베젤 주변에 접착제가 더 많이 사용되었습니다.
지문 센서 근처 왼편 가장자리를 조심히 자르지 않으면 내부 리본 케이블이 손상될 위험이 있습니다.
It's extremely easy to crack the back glass when nearing and rounding the corners. It's probably a good idea to soften the adhesive with heat as you go.
Step 5 is NOT "cut through the adhesive", that's steps 5-10. Step 5 is "Begin the careful process of cutting through the adhesive, starting at the right side where you already softened it. Proceed carefully, slowly, and warmly through the following steps."
These comments are spot-on. I never break a phone, and I cracked the back glass following the instructions without seeing these comments first. Heat the back much more than you think you need and go super, super slow.
상단-오른쪽 모서리에 여는 픽을 남겨두세요.
다른 여는 픽을 사용하여 하단-오른편 모서리 주변의 접착제를 자르세요.
휴대폰에 여는 픽을 남겨두세요.
There seems to be a lot of glue at the bottom, I broke the glass as I was cutting past the charging port - not sure if it was already fractured or just not enough heat (I used Sellotape so it didn't break up into pieces!)
I think LOTS of heat & patience is the key!
Be very careful around the corners and bottom (probably top too, but I didn't have a problem there). Make sure you've cut in far enough down the side first (go in about 1cm) but less round the corners and work in slowly.
열선 총 또는 헤어 드라이어를 사용하거나 가열한 iOpener를 후면 패널의 왼편에 약 1분 동안 적용하여 아랫면의 접착제를 부드럽게 하세요.
꽂혀있는 여는 픽을 사용하여 후면 패널 상단-왼쪽 모서리 주위의 접착제를 조심히 자르세요.
끝으로, 휴대폰 상단을 따라 나머지 접착제를 자르세요.
Be VERY patient as you slide the opening picks around the periphery of the glass, and use heat very liberally. Make sure the smooth, clear aspect of the iOpener is against the glass, not the rough black portion.
먼저 후면 커버 오른편을 분리하세요.
왼편 가장자리를 따라 커버를 위로 기울여 지문 센서 리본 케이블을 드러내세요.
Thought I'd done something wrong here as there wasn't a cable attached to the back - the fingerprint reader hadn't come away with the back, but had stayed with the phone.
Exactly the same experience. Made life a little easier.
Happened to me as well.
Spudger/스퍼저 끝을 사용하여 지문 센서 리본 케이블을 소켓에서 들어올려 빼세요.
후면 커버를 분리하세요.
핀셋을 사용하여 휴대폰 섀시에 남아 있는 접착제를 제거하세요. 그 다음 (최소 90%) 고농도 이소프로필 알코올과 보풀-없는 천으로 접착 부분을 청소하여 새 접착 표면을 준비하세요.
새 접착제를 설치하고 휴대폰을 다시 닫기 전에 휴대폰을 켜고 수리를 테스트하세요.
새 접착제를 후면 커버에 조심히 바르고, 유리의 한쪽 가장자리를 휴대폰 섀시에 맞추고 유리를 휴대폰에 단단히 누르세요.
I am installing a new backplate (this is my first repair; I was CERTAIN that I would crack the back glass, and I was NOT wrong) but I’m not sure how tweezers are meant to remove gooey adhesive! I simply used the blue plastic pry tool as a scraper and gently rolled up the goo. Maybe the glue is different because I have a refurbished phone? That may also explain why I had so much trouble with Step 1. Hope that this helps!
14 단계 상단 중앙프레임 분리하기
주의: 14-17 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Phillips/십자 스크류드라이버를 사용하여 상단 중앙프레임을 고정하는 4mm 나사 아홉 개를 풀어주세요.
There are two more screws on the bottom right corner of the little side frame that the Qi plate is glued to. I took those out as it put less stress on it.
John Stone - 답글
It helps to hold the fine tweezers with your non-dominant hand to support the screw heads and ensure they come straight out; you can also gently lift as you unscrew.
Spudger/스퍼저의 평평한 끝을 사용하여 마더보드에서 충전 어셈블리를 분리하세요.
These screws are supposed to be 3.2 mm because when I took out these screws, they were shorter than the ones you take out first
기기를 재조립하려면, 위의 단계들을 역순으로 따르세요.
전자 폐기물을 R2 또는 e-Stewards 인증 재활용 센터로 가져가세요.
수리가 계획대로 진행되지 않았습니까? 자사의
답변 커뮤니티에서 문제해결 도움을 받으세요.
새 교체 부품을 원래 부품과 비교하세요—설치하기 전에 나머지 부품을 옮기거나 새 부품에서 접착 뒷면을 제거해야 할 수 있습니다.
다른 8명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 5개
Thats a really great instruction. I also have a question. Can I replace the internal memory in a new Note 9 phone from an old Note 9 Phone? If yes, will it work and does it have to be same storage size?
Thank you
Thank you! Unfortunately this is not possible because the memory is soldered to the motherboard. What you can do is swap the entire motherboard from an old phone into the new one but I haven’t tested this myself so I can’t guarantee that everything will work properly. I expect it to work though—including for larger storage sizes—because I do not know of any parts that are paired to the motherboard on those phones.
Hi, can i replace a dual sim Note 9 with a single sim Motherboard?
