주요 콘텐츠로 건너뛰기
Samsung Galaxy On5 Battery Replacement
필요한 것
  1. Samsung Galaxy On5 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the side notch that allows you to open the back casing.
  2. Samsung Galaxy On5 Battery Replacement: 2 단계, 이미지 1/3 Samsung Galaxy On5 Battery Replacement: 2 단계, 이미지 2/3 Samsung Galaxy On5 Battery Replacement: 2 단계, 이미지 3/3
    • Use a plastic prying tool or your fingernail to pop the back cover off of the phone.
  3. Samsung Galaxy On5 Battery Replacement: 3 단계, 이미지 1/3 Samsung Galaxy On5 Battery Replacement: 3 단계, 이미지 2/3 Samsung Galaxy On5 Battery Replacement: 3 단계, 이미지 3/3
    • Locate the battery notch and remove the battery, using either your finger or a plastic prying tool.
    • Be careful not to puncture the battery. Lithium-ion batteries are highly flammable when exposed to oxygen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
The Dark Night part 2
회원 가입일: 09/19/18
983 평판
안내서 5개 작성하였습니다
Gateway, Team S1-G5, Luster Fall 2018 Gateway, Team S1-G5, Luster Fall 2018 회원
GCC-LUSTER-F18S1G5
1 회원
안내서 5개 작성하였습니다
댓글 한 개
I had buy a new Samsung Galaxy On5 Battery Replacement and I never got it can i get ti for free i pay for the battery and that all and i had buy a SDM crad and i never got ti and that all
Malachi Hadley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 1,570
