주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If you own the Samsung Galaxy On5 replacing the battery is a breeze. If your phone isn't turning on or the screen is frozen, use these steps to remove the battery.
부품
지정된 부품이 없습니다.
  1. Locate the side notch that allows you to open the back casing.
    • Locate the side notch that allows you to open the back casing.
  2. Use a plastic prying tool or your fingernail to pop the back cover off of the phone. Use a plastic prying tool or your fingernail to pop the back cover off of the phone. Use a plastic prying tool or your fingernail to pop the back cover off of the phone.
    • Use a plastic prying tool or your fingernail to pop the back cover off of the phone.
  3. Locate the battery notch and remove the battery, using either your finger or a plastic prying tool. Be careful not to puncture the battery. Lithium-ion batteries are highly flammable when exposed to oxygen. Be careful not to puncture the battery. Lithium-ion batteries are highly flammable when exposed to oxygen.
    • Locate the battery notch and remove the battery, using either your finger or a plastic prying tool.
    • Be careful not to puncture the battery. Lithium-ion batteries are highly flammable when exposed to oxygen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
The Dark Night part 2
회원 가입일: 2018년 09월 19일
836 평판
안내서 5개 작성하였습니다
Gateway, Team S1-G5, Luster Fall 2018 Gateway, Team S1-G5, Luster Fall 2018 회원
GCC-LUSTER-F18S1G5
1 회원
안내서 5개 작성하였습니다
I had buy a new Samsung Galaxy On5 Battery Replacement and I never got it can i get ti for free i pay for the battery and that all and i had buy a SDM crad and i never got ti and that all
Malachi Hadley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 26
전체 시간: 829
