소개
The Samsung Galaxy On5 comes with two cameras, one front-facing and one rear-facing camera. This guide will walk you through replacing both.
필요한 것
Use a plastic pry tool to lift the front-facing camera from its housing.
Using a Phillips #00 screwdriver, remove the screw securing the rear-facing camera.
That's it, now you've removed both the front and rear facing cameras on your device! To reassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
