주요 콘텐츠로 건너뛰기
Samsung Galaxy Player 5.0 Battery Replacement
필요한 것
  1. Samsung Galaxy Player 5.0 Battery Replacement, Battery: 1 단계, 이미지 1/2 Samsung Galaxy Player 5.0 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the SD Memory Card before taking the device apart. Using the screwdriver, remove the 10mm Phillips screw that is near the SD Memory Card port.
  2. Samsung Galaxy Player 5.0 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the white caps, which are covering the screws that are located on either side of the charging port.
    • You may have to use a low heat blow dryer for 5 to 10 seconds, or other equivalent heat source to loosen the adhesive.
  3. Samsung Galaxy Player 5.0 Battery Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Player 5.0 Battery Replacement: 3 단계, 이미지 2/2
    • Continue to unscrew the two 10mm Phillips Screws from the bottom of the device.
  4. Samsung Galaxy Player 5.0 Battery Replacement: 4 단계, 이미지 1/1
    • Starting from the bottom and working around, use the prying tool to separate the front cover housing from the back cover housing.
    • You will hear a popping sound, indicating the separation.
  5. Samsung Galaxy Player 5.0 Battery Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Player 5.0 Battery Replacement: 5 단계, 이미지 2/2
    • Take the back housing cover off of the device.
  6. Samsung Galaxy Player 5.0 Battery Replacement: 6 단계, 이미지 1/1
    • Using the prying tool, remove the tab that attaches the battery to the motherboard.
  7. Samsung Galaxy Player 5.0 Battery Replacement: 7 단계, 이미지 1/3 Samsung Galaxy Player 5.0 Battery Replacement: 7 단계, 이미지 2/3 Samsung Galaxy Player 5.0 Battery Replacement: 7 단계, 이미지 3/3
    • Then remove the battery, using the prying tool in an upward motion.
    • There is an adhesive behind the battery but it is not strong.
  8. Samsung Galaxy Player 5.0 Battery Replacement: 8 단계, 이미지 1/3 Samsung Galaxy Player 5.0 Battery Replacement: 8 단계, 이미지 2/3 Samsung Galaxy Player 5.0 Battery Replacement: 8 단계, 이미지 3/3
    • Insert the new battery into its position, and reconnect its tab onto the motherboard.
  9. Samsung Galaxy Player 5.0 Battery Replacement: 9 단계, 이미지 1/1
    • Now put the rear housing cover on the device, starting from its bottom side, and snap the edges all the way around to close the device.
  10. Samsung Galaxy Player 5.0 Battery Replacement: 10 단계, 이미지 1/3 Samsung Galaxy Player 5.0 Battery Replacement: 10 단계, 이미지 2/3 Samsung Galaxy Player 5.0 Battery Replacement: 10 단계, 이미지 3/3
    • Lastly, reinsert the screws at the bottom of the device, as well as the screw beside the SD Memory Card port.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
China Ayala
회원 가입일: 03/05/15
584 평판
안내서 4개 작성하였습니다
Sam Houston State, Team 11-7, Blackburne Winter 2015 Sam Houston State, Team 11-7, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G7
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 18
전체 시간: 3,472
