주요 콘텐츠로 건너뛰기
Samsung Galaxy Player 5.0 Screen Replacement
필요한 것
  1. Samsung Galaxy Player 5.0 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Remove the SD card before disassembling the device.
    • Use a screwdriver to remove the screw near the SD card.
  2. Samsung Galaxy Player 5.0 Screen Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Player 5.0 Screen Replacement: 2 단계, 이미지 2/2
    • Go to the bottom of the device and remove the white caps covering the screws.
    • If it is difficult to remove the white caps, use a heat blower to heat them before removing them.
    • After removing the caps, use a screwdriver to remove the screws at the bottom of the device. Set aside.
  3. Samsung Galaxy Player 5.0 Screen Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Player 5.0 Screen Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Player 5.0 Screen Replacement: 3 단계, 이미지 3/3
    • Starting from the bottom, use a pry tool to separate the front housing cover from the back cover.
    • Use a plastic prying tool if you can. Be extremely careful when separating the front housing cover.
    • Pull the front and back cover halves apart completely.
  4. Samsung Galaxy Player 5.0 Screen Replacement: 4 단계, 이미지 1/1
    • Use the pry tool to separate the tab connecting the battery and motherboard.
  5. Samsung Galaxy Player 5.0 Screen Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Use the prying tool to separate the battery from the motherboard.
    • Metal spudgers and similar pry tools can puncture an unprotected battery, potentially causing a fire. To be on the safe side, it’s better to use a plastic card or nylon spudger.
  6. Samsung Galaxy Player 5.0 Screen Replacement: 6 단계, 이미지 1/1
    • Remove the ear piece using a pry tool. Set aside.
  7. Samsung Galaxy Player 5.0 Screen Replacement: 7 단계, 이미지 1/1
    • Remove the front and rear cameras.
  8. Samsung Galaxy Player 5.0 Screen Replacement: 8 단계, 이미지 1/1
    • Disconnect the volume button from the motherboard.
    • It is not necessary to completely remove the volume buttons from the device after they have been disconnected.
  9. Samsung Galaxy Player 5.0 Screen Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Player 5.0 Screen Replacement: 9 단계, 이미지 2/2
    • Use a screwdriver to remove the screw pictured.
    • Use a prying tool to remove the headphone jack.
    • Set both carefully aside.
  10. Samsung Galaxy Player 5.0 Screen Replacement: 10 단계, 이미지 1/1
    • Disconnect the mean button flex cable.
    • Use a pry tool to open the locker on the motherboard and remove flex cable.
  11. Samsung Galaxy Player 5.0 Screen Replacement: 11 단계, 이미지 1/2 Samsung Galaxy Player 5.0 Screen Replacement: 11 단계, 이미지 2/2
    • Disconnect the LCD flex cable.
    • Use a screwdriver to remove six screws pictured.
  12. Samsung Galaxy Player 5.0 Screen Replacement: 12 단계, 이미지 1/3 Samsung Galaxy Player 5.0 Screen Replacement: 12 단계, 이미지 2/3 Samsung Galaxy Player 5.0 Screen Replacement: 12 단계, 이미지 3/3
    • Hold the PCD unit and lift it up.
    • Switch out the old digitizer for the new one. Reconnect all the cables and screws in the reverse sequence.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Wenbin Weng
회원 가입일: 01/28/17
122 평판
안내서 1개 작성함
IUPUI, Team S4-G4, Wilson Spring 2017 IUPUI, Team S4-G4, Wilson Spring 2017 회원
IUPUI-WILSON-S17S4G4
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 6
전체 시간: 677
