주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Loudspeaker: 1 단계, 이미지 3개 중 1개 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Loudspeaker: 1 단계, 이미지 3개 중 2개 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Loudspeaker: 1 단계, 이미지 3개 중 3개
    • Remove any SIM and SD card.
    • Remove 7x Phillips screws.
    • Use a plastic tool to disassemble the rear housing.
    댓글 쓰기
  2. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: 2 단계, 이미지 1개 중 1개
    • The Loudspeaker is located on the rear housing..
    댓글 쓰기
  3. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Logic Board: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Logic Board: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Logic Board: 3 단계, 이미지 3개 중 3개
    • Disconnect the LCD Display flex cable.
    • Lift up the board and disconnect the Touchscreen flex cable.
    • Now you can remove the Motherboard.
    댓글 쓰기
  4. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Touchscreen, Digitizer Glass, LCD Display: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Touchscreen, Digitizer Glass, LCD Display: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Touchscreen, Digitizer Glass, LCD Display: 4 단계, 이미지 3개 중 3개
    • Warm the touchscreen to make separating the LCD Display more easy
    • For this manipulation you can use a hair drier.
    • In the four corners of LCD display there are small metal plates. Use one of them to lift a little the LCD and put the plastic tool.
    • Be careful not to break the display.
    댓글 쓰기
  5. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: 5 단계, 이미지 3개 중 3개
    • After separating the LCD Display, again worm the Touchscreen.
    • If the glass is broken, put a transparent tape to prevent scattering.
    댓글 쓰기
  6. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: 6 단계, 이미지 3개 중 3개
    • Use plastic tools and slowly separate the touch screen from the front bezel.
    댓글 쓰기
  7. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: 7 단계, 이미지 3개 중 1개 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: 7 단계, 이미지 3개 중 2개 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: 7 단계, 이미지 3개 중 3개
    • If the new spare part has come without adhesive tape. you must put.
    • Reassemble your device, follow these instructions in reverse order.
    댓글 쓰기
  8. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: 8 단계, 이미지 1개 중 1개
    • Did you do it successfully?
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
197,270 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
334 회원들
안내서 1,701개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 44
전체 시간: 7,967
