소개
You may need to replace your battery if your current battery is damaged, or is not attaining power from an outlet. No background information is required.
필요한 것
Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 3개
I just replaced the battery about a month ago after turning phone off and the turned back on it stuck on screen with samsung and the other lights stayed on
Mine doing the same
