주요 콘텐츠로 건너뛰기
Samsung Galaxy Prevail 2 Home Button Replacement
필요한 것
  1. Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: 1 단계, 이미지 3개 중 1개 Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: 1 단계, 이미지 3개 중 2개 Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: 1 단계, 이미지 3개 중 3개
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: 2 단계, 이미지 3개 중 3개
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Screws: 3 단계, 이미지 2개 중 1개 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Screws: 3 단계, 이미지 2개 중 2개
    • Unscrew all of the screws.
    • Be sure to set aside in a safe place.
  4. Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: 4 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool between the silver frame and the white face of the phone to pry off the front face.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone
  5. Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: 5 단계, 이미지 3개 중 3개
    • With the plastic opening tool, lift up the flap to to fully open the motherboard.
  6. Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: 6 단계, 이미지 3개 중 3개
    • With the plastic opening tool, lift the second flap up.
  7. Samsung Galaxy Prevail 2 Home Button Replacement, Locate Home Button: 7 단계, 이미지 2개 중 1개 Samsung Galaxy Prevail 2 Home Button Replacement, Locate Home Button: 7 단계, 이미지 2개 중 2개
    • Choose the motherboard side that contains the home button, as shown in the image.
  8. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Home Button: 8 단계, 이미지 2개 중 1개 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Home Button: 8 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to push the home button out.
    • Push the button from the face of the phone inwards as indicated in the first image.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Garrett Bowleg
회원 가입일: 10/08/14
487 평판
안내서 2개를 작성함
USF Tampa, Team 14-4, Leahy Fall 2014 USF Tampa, Team 14-4, Leahy Fall 2014 회원
USFT-LEAHY-F14S14G4
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 2,234
