주요 콘텐츠로 건너뛰기
Samsung Galaxy Prevail 2 Vibrator Replacement
필요한 것
  1. Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: 1 단계, 이미지 1/3 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: 1 단계, 이미지 2/3 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: 1 단계, 이미지 3/3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: 2 단계, 이미지 1/3 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: 2 단계, 이미지 2/3 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: 2 단계, 이미지 3/3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: 3 단계, 이미지 1/2 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: 3 단계, 이미지 2/2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: 4 단계, 이미지 1/3 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: 4 단계, 이미지 2/3 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: 4 단계, 이미지 3/3
    • Insert the plastic prying tool between the silver frame and the white face of the phone. to pry off the front frame.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone.
  5. Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: 5 단계, 이미지 1/3 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: 5 단계, 이미지 2/3 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: 5 단계, 이미지 3/3
    • With the plastic prying tool, lift up the flap in order to fully open the motherboard.
  6. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: 6 단계, 이미지 1/3 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: 6 단계, 이미지 2/3 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: 6 단계, 이미지 3/3
    • With plastic prying tool, lift the flap up to divide the motherboard.
    • This will make it easier to detach the internal battery.
  7. Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: 7 단계, 이미지 1/3 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: 7 단계, 이미지 2/3 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: 7 단계, 이미지 3/3
    • With plastic prying tool, lift up the vibration motor.
  8. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Vibration Motor: 8 단계, 이미지 1/1
    • With the soldering iron remove the solder attaching the vibration motor to the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Garrett Bowleg
회원 가입일: 10/08/14
469 평판
안내서 2개 작성하였습니다
USF Tampa, Team 14-4, Leahy Fall 2014 USF Tampa, Team 14-4, Leahy Fall 2014 회원
USFT-LEAHY-F14S14G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 989
