주요 콘텐츠로 건너뛰기
Samsung Galaxy Prevail Touch Screen Replacement
필요한 것
  1. Samsung Galaxy Prevail Touch Screen Replacement, Touch Screen: 1 단계, 이미지 1개 중 1개
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Touch Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Touch Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Touch Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Using the black spudger, carefully unhinge and pry the secondary rear panel , which houses the camera lens and speaker.
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Touch Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Using the spudger, gently pry upward on the motherboard by the right side.
    • Motherboard is connected to shield plate with ribbon cable.
  6. Samsung Galaxy Prevail Touch Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Using a spudger, carefully unhinge the gray shield plate by lifting upwards on the right side.
    • The shield plate will not be fully removed, it is attached to the front panel with a ribbon cable.
  7. Samsung Galaxy Prevail Touch Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Using the spudger lift up the LCD screen and replace with the new screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ricardo Zuloaga
회원 가입일: 09/15/16
537 평판
안내서 5개를 작성함
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G6
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 12
전체 시간: 898
