주요 콘텐츠로 건너뛰기
Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement
필요한 것
  1. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement, Volume, Camera, & Power Buttons: 1 단계, 이미지 1개 중 1개
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Using the spudger, gently pry upward on the motherboard by the right side.
    • Motherboard is connected to shield plate with ribbon cable.
  6. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the desired button by pushing inward with the spudger or disconnecting the rubber pin connections.
결론
작성자
4다른 기여자 명과 함께
Ricardo Zuloaga
회원 가입일: 09/15/16
537 평판
안내서 5개를 작성함
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G6
3 회원들
안내서 5개를 작성함
0 Guide Comments
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 20
전체 시간: 279
